Cura show ghost point of the object if is it in horizontal position, but the object appear and print well only vertical position (or with more angle)
Posted
· Cura show ghost point of the object if is it in horizontal position, but the object appear and print well only vertical position (or with more angle)
It doesn't happen for me using a .4 nozzle and .4 Line Width. When you orient it vertically then Layer Height is the limiting factor. When it's oriented horizontally then Line Width is the limiting factor.
Posted
Thanks!
GregValiant 1,115
john_vlahidis 0
Thanks!
