Posted (edited) · Cura 4.10 first-layer problem with skirt
Hello,
Cura 4.10 damages the first layer if Build Plate Adhesion is set to Skirt. See attached screenshots.
Top: Build Plate Adhesion is set to Brim.
Bottom: Build Plate Adhesion is set to Skirt. As you can see the ventilation-grid is missing. It starts at layer 2. This does not work properly, you get a spaghetti-ventilation.
Edited by esopalumpa
    • esopalumpa changed the title to Cura 4.10 first-layer problem with skirt
    Posted · Cura 4.10 first-layer problem with skirt
    Check the Initial Layer Horizontal Expansion.  Make sure it is set to "0".  It's possible that Horizontal Hole Expansion is a problem but if the thin features show up on subsequent layers then the problem may well be the Initial Layer Horizontal Expansion.  I don't think there should be difference between Skirt and Brim though.  Are you using two different profiles with one set for skirt and the other for brim?
    • 1 month later...
    Ups, I forgot to comment, sorry
    Yes, it was Initial Layer Horizontal Expansion and no, the profiles are identical except for Build Plate Adhesion Type.
    BI
