7 hours ago, 44mlb said:now crash the print head into the side of the printer (Ultimaker 2+)
I need a better description. Please video the 3 seconds or so when it crashes. There are 10 possible issues that can all be described as "crash the print head into the side". I'm going to guess it happens during homing and you are not reaching the limit switch. If that happens it makes a horrible sound but nothing is damaged on your printer.
The limit switch may have moved a little and maybe you need to move it back or maybe it's one of the rods through the print head don't hit the switch anymore or maybe your fan shroud is bent and hitting the side of your printer. I can determine all of this in a 3 second video of the problem happening.
gr5 1,870
That's the easier thing to fix. First select a printer again - maybe select a *different* UM2+ than you had selected before.
Go to left side of screen in PREPARE mode. Click on your printer, then do "manage printers" then "machine settings".
Now change the gcode style - I think you had it on Marlin maybe? Change it to ultigcode.
