Netfabb 4.9 Outline ???
wombl1
Posted · Netfabb 4.9 Outline ???
does anybody know where the outline feature disappeared ?
I could really use it, but i can not find it in the release ...
not even in the release notes .... nowhere ....
Maybe someone can help ...
Kind regards,
Robert
    Hi Robert,
    did you had a look in the Raft selection menu? This was the spot where you could select it as a raft type in the early betas. I didn't had the time yet to look into it myself. Get back to you in more details after I checked it.
    Quite some work to do from what I've read so far....
    Cheers,
    Flo
    Yes, it's right there, under the print tab, raft type: outline (netfabb 4.9)
    a quick 'calculate toolpath' confirms that it is indeed printing a single outline
