Thanks for your answer, i have Support disabled so i'm not using that at all.. Thats the weird part about it
Here is both attached, modified being the newer one that is having me problems.. I can also attach both GCodes
CE3PRO_SlicedV2BottomPartRaft.3mf CE3PRO_SlicedV2BottomPartRaftMODIFIED.3mf
GregValiant 1,112
That circle is the raft. There is one tab that hits the build plate and the rest of the bottom is elevated. In order to print correctly it needs support as the main body bottom is 15 layers off the build plate.
Here is the preview of the "Modified" file.
Here is the model sliced with Support turned on. There are 14 layers of raft and support before the bottom of the piece shows up on Layer 15. I realize this needs a lot of support but when you have areas that start in thin air there has to be something for it to print on. Air printing never turns out well.
This is with support turned off. There is no way that piece starting out in space will print correctly. A lot of that overhang has the same problem.
Edited by GregValiant
GregValiant 1,112
It might be a prime tower. Under Support see if you have "Use Towers" checked. If it isn't visible then you can search for it or turn setting visibility to "All".
