I've never had good results right after cleaning a plate, even with 99% IPA. It seems like it just takes a bunch of heat cycles/failed prints to "season" the plates and then they work very reliably.
I also recommend using some kind of gluestick or Magigoo or similar. If for nothing else but to add a protective barrier between your parts and the glass. You can often get really good adhesion with plain glass but you would be surprised how easy it is for the the glass to chip off when you remove parts.
1
Smithy 1,141
I always use a thin layer of UHU stick to have a good adhesion in all situations. Plain glass can work but depends on the geometry of your model if it really works or not.
