Pictures would help. Maybe we'd get some ideas.
I found variable infill (gradual infill steps) to be a good time saver - I can usually save 20% of print time with that feature. I only use it for parts that I will make over and over again as I keep tweaking it after each print until I get my prints really fast and also accurate.
Also using a 0.8mm nozzle might be a good time saver. Or 0.6mm nozzle. It depends on the part.
1
Smithy 1,116
Everyone has different needs and views what's acceptable and what not. So there will be no general advise how to do. You can only decide for your specific project what is important for you.
Increased speed settings results most of the time in a decreased quality.
A bigger layer height can help and decreases the print time.
Also less infill percentage.
Decrease wall lines.
Decrease top/bottom layers
After slicing, hover over the print time and you will get a popup with the details which give a rough indication where you "loose" the time.
andygomez3dart 0
Thanks. I can see there is always something to Sacrifice between quality/printing time.
I've been slicing a very complex skull (approx. 100x100x114mm)
- Loads of overhangs
- 1.2mm wall thickness 3 wall lines
- 0% Infill & 0.2mm Layer height
- Speed (40-60mm/s and 30mm/s Top/Bottom) plus 150mm travel speed.
The biggest problem is the time spent building supports even using,Zig Zag build plate only and 12% support density.
But I am afraid If Increase speed It's very likely to brake parts as the nozzle travel between overhangs/bridges or those thin supports.
I tweaked several acceptable options but I don't really want to go lower than 0.2mm quality neither split the 3d model.
I rotated the 3d model in several positions and still with the above speed/Quality It's so frustrating not being able to get a print under 8 hours.
Regards,
Andy
