Most probably there are errors in the model. The x-ray-view in Cura highlights errors that are found.
"Mesh tools" can do some simple repairs (right mouse click on the model).
Some things to check in Blender:
Is the model manifold?
Check for doubled or missing faces, and check for non connected or overlapping vertices. Always do a "merge by distance" in edit mode before exporting, just to be sure.
Check the normals - are all facing in the right direction? 'Face orientation' can be enabled in the viewport overlay.
tinkergnome 929
Good luck!
HC93 0
Problem solved, thank you very much!
In my case, I had no overlapping vertices, but some of the faces had bad orientations.
I modified it on the Blender model and now it's good.
All my best,
Hugo
