14 hours ago, GregValiant said:Once you get things to stick to the bed, the number one problem becomes extrusion. If you haven't done it yet - calibrate your E-steps. When the printer is asked to extrude 100mm of filament it needs to move 100mm of filament. Most Enders need this done and there are a lot of videos out there.
The second thing is the mechanicals. The 3 axes need to be perpindicular to each other (not just "close enough") and the belts and wheels need to be adjusted for easy movement with no wobbling of the print head or skipping of teeth on the belts.
If you want to post a 3mf file of your project you can load a model and set up Cura for slicing and then use "File | Save Project" to create a 3mf file and post it here. Somebody will take a look.
Here is the file I'm trying to print. I'll do all of those things and will see where that gets me. I'll post result in the forum Thanks!
GregValiant 1,231
