Possible Under extrusion approaching Z seam on interior wall
revcanon
Posted (edited) · Possible Under extrusion approaching Z seam on interior wall
Printing Cookie Cutters.
Ultimaker Cura 4.11.0
Creality Ender 3 Pro w/ .4 mm nozzle
eSun PLA+ 1.75 mm
Wall thickness is designed at 1.2 mm using Fusion 360.
Initially, I though coasting /coasting volume was the problem, but turning off coasting made no difference.
I noticed that the filament was curling as it exited the hot end, so I cleared it with an acupuncture needle and the curling no longer happens. The severity of the issue seemed to lessen, but was not eliminated completely.
The handle of the cutter (bottom 3 mm of the first pic) prints well, but the interior wall of the 1.2mm cutter blade gets thinner as it approaches the Z seam in each layer.  The finished product has a visibly thinner wall on the one side of the seam, but only on the inner wall. The outer wall is fine and appears the same on both sides of the seam.
Second pic is backlit so you can see there is a difference in thickness on either side of the seam.
I am not concerned with a visible seam, I am concerned with the wall being weak. As this would be for a cookie cutter, that is very bad.
I have included the stl, gcode, and curaprofile files.
Any help is appreciated.
EDIT: UPDATE:  Possible heat creep issue. Replaced bowden tube, found a filament blockage within the hot end. It may be that I'm under extruding at lower pressure due to constricted path for filament.  Cleaned up and printing new test now.  Looks good so far.....
EDIT 2: 1 print seemed fine, 2nd print began doing it again. How do I solve for this?
Untitled v1.stl CE3PRO_Untitled v1.gcode CookieCutters.curaprofile
Edited by revcanon
    Posted · Possible Under extrusion approaching Z seam on interior wall
    5 hours ago, NomakeR said:
    hey man, if your problem is the z seam being weak, I'd suggest you to choose random z seam alignment.
    It's not the z seam itself. It's the intereior wall at the end of the printing as it approaches the z seam. it starts part way through the line and gets worse as it approaches the z seam.   I did random z seam and it just deposits this problem randomly throughout the inner wall.
        • 4 replies
