Yes, I see. So please explain to me why the Cura update had to wipe out the profile I made myself? That, by the way, provided a very smooth printing experience.
20 hours ago, Flutelab said:Yes, I see. So please explain to me why the Cura update had to wipe out the profile I made myself? That, by the way, provided a very smooth printing experience.
Did you select "Uninstall all older Cura versions" in the install? It also asks you if you want to remove all old profiles.
It could also be that it failed to convert the profile, but I would need your log files to be able to find that out.
I can also recommend using the backup functionality that is built in with Cura, since it syncs your config with the Cloud, so you will always have your settings stored in a safe place.
Wow! I did not know this functionality existed, thanks
Maarten
nallath 1,125
Thanks for doing so though!
Yes, at a certain point we have to choose how to spend our time. It sucks that we have to, but we released this machine 5 years ago. So when making choices about what we back-port, we have to make tough choices like this.
Note that "not supported" doesn't mean "you can't do it". It just means that we don't provide fully tuned profiles for this. It is possible to print TPLA on the UM2+, it just doesn't have an as smooth experience.
