Cura 4.11 Freezing on "Loading UI", Opens when run as Admin
braveheartJM
Posted · Cura 4.11 Freezing on "Loading UI", Opens when run as Admin
Trying to boot up Cura, but it will only load up when I run it as an Admin. If I use the shortcut or the .exe, it stops at the "Loading UI" screen.
I do have a lot of plugins downloaded (Startup Optimizer, Parts For Calibration, Solidworks Integration, Auto Orientation, Thingibrowser, Custom Naming, Octoprint Connection) so that decreases performance slightly. Doesn't make sense why it works in Admin mode.
I did disable the setting of "Restore Window Position on Start" and that didn't change anything.
Application Version
4.11.0
Platform
Windows 10
Reproduction steps
open app
stuck at "loading UI", app crashes
cura.log
