Yes it is, I don't know the English name, but in Austria we call these panels "Alu Dibond".
But I think it is easier to buy this spare part from your reseller or @fbrc8-erin can help you directly.
We call the material Dibond. For most any other panel, a replacement panel should be pretty readily available. For the back panel it's a little different; removing the back panel exposes the power supply, so back panel replacements should be done where the machine can be HiPot tested for safety.
Smithy 1,144
The source files are not open source (yet) of the S5, so you will not find any files related to it.
But you should be able to order the part at your reseller.
JasonBennett 0
Thanks for the info Smithy. Upon closer inspection that frame panel is actually made of metal, so it would be more complicated to reproduce anyway. I'll check with my reseller.
