calling CuraEngine from the terminal (possible bug... although probably I'm doing something wrong)
vito2101
Posted · calling CuraEngine from the terminal (possible bug... although probably I'm doing something wrong)
Hi good day.
I have a rather strange situation (don't know if someone else has crossed with it) .
I'm running Cura Engine from a ubuntu 20.04 terminal which (at first) it seems like it is delivering a proper gcode. However when I check the file in Ultimaker Cura I discover that actually the height of the objects is smaller. For instance if the piece is 24 mm tall, with a 0.1 layer height, it should deliver 240 layers, however it is delivering 199.
What I do is this:
in the terminal (to set CURA_ENGINE_SEARCH_PATH as stated in https://github.com/Ultimaker/CuraEngine)
export CURA_ENGINE_SEARCH_PATH=/snap/cura-slicer/51/usr/share/cura/resources/definitions:/snap/cura-slicer/51/usr/share/cura/resources/extruders
then I call CuraEngine like this
/snap/cura-slicer/51/usr/bin/CuraEngine  slice -v -p -j /snap/cura-slicer/51/usr/share/cura/resources/definitions/creality_ender3.def.json  -o output.gcode   -l my_stl_file.stl
The output is this
[WARNING] Unrecognized data type in JSON setting machine_disallowed_areas
[WARNING] Unrecognized data type in JSON setting nozzle_disallowed_areas
[WARNING] Unrecognized data type in JSON setting machine_head_with_fans_polygon
[WARNING] JSON setting machine_max_feedrate_x has no default_value!
[WARNING] JSON setting machine_max_feedrate_y has no default_value!
[WARNING] JSON setting machine_max_feedrate_z has no default_value!
[WARNING] JSON setting machine_max_feedrate_e has no default_value!
[WARNING] JSON setting machine_max_acceleration_x has no default_value!
[WARNING] JSON setting machine_max_acceleration_y has no default_value!
[WARNING] JSON setting machine_max_acceleration_z has no default_value!
[WARNING] JSON setting machine_max_acceleration_e has no default_value!
[WARNING] JSON setting machine_acceleration has no default_value!
[WARNING] JSON setting machine_max_jerk_xy has no default_value!
[WARNING] JSON setting machine_max_jerk_z has no default_value!
[WARNING] JSON setting machine_max_jerk_e has no default_value!
[WARNING] JSON setting acceleration_print has no default_value!
[WARNING] JSON setting acceleration_travel has no default_value!
[WARNING] JSON setting acceleration_travel_layer_0 has no default_value!
[WARNING] JSON setting acceleration_roofing has no default_value!
[WARNING] JSON setting jerk_print has no default_value!
[WARNING] JSON setting jerk_travel has no default_value!
[WARNING] JSON setting jerk_travel_layer_0 has no default_value!
[WARNING] JSON setting acceleration_enabled has no default_value!
[WARNING] JSON setting jerk_enabled has no default_value!
[WARNING] JSON setting speed_print has no default_value!
[WARNING] JSON setting speed_infill has no default_value!
[WARNING] JSON setting speed_wall has no default_value!
[WARNING] JSON setting speed_wall_0 has no default_value!
[WARNING] JSON setting speed_wall_x has no default_value!
[WARNING] JSON setting speed_topbottom has no default_value!
[WARNING] JSON setting speed_roofing has no default_value!
[WARNING] JSON setting speed_travel has no default_value!
[WARNING] JSON setting speed_layer_0 has no default_value!
[WARNING] JSON setting speed_print_layer_0 has no default_value!
[WARNING] JSON setting speed_travel_layer_0 has no default_value!
[WARNING] JSON setting speed_prime_tower has no default_value!
[WARNING] JSON setting speed_support has no default_value!
[WARNING] JSON setting speed_support_interface has no default_value!
[WARNING] JSON setting speed_z_hop has no default_value!
[WARNING] JSON setting skirt_brim_speed has no default_value!
[WARNING] JSON setting line_width has no default_value!
[WARNING] JSON setting optimize_wall_printing_order has no default_value!
[WARNING] JSON setting material_initial_print_temperature has no default_value!
[WARNING] JSON setting material_final_print_temperature has no default_value!
[WARNING] JSON setting material_flow has no default_value!
[WARNING] JSON setting travel_compensate_overlapping_walls_0_enabled has no default_value!
[WARNING] JSON setting z_seam_type has no default_value!
[WARNING] JSON setting z_seam_corner has no default_value!
[WARNING] JSON setting infill_sparse_density has no default_value!
[WARNING] JSON setting infill_pattern has no default_value!
[WARNING] JSON setting infill_before_walls has no default_value!
[WARNING] JSON setting infill_overlap has no default_value!
[WARNING] JSON setting skin_overlap has no default_value!
[WARNING] JSON setting infill_wipe_dist has no default_value!
[WARNING] JSON setting wall_0_wipe_dist has no default_value!
[WARNING] JSON setting fill_perimeter_gaps has no default_value!
[WARNING] JSON setting fill_outline_gaps has no default_value!
[WARNING] JSON setting filter_out_tiny_gaps has no default_value!
[WARNING] JSON setting retraction_speed has no default_value!
[WARNING] JSON setting retraction_retract_speed has no default_value!
[WARNING] JSON setting retraction_prime_speed has no default_value!
[WARNING] JSON setting retraction_hop_enabled has no default_value!
[WARNING] JSON setting retraction_hop has no default_value!
[WARNING] JSON setting retraction_combing has no default_value!
[WARNING] JSON setting retraction_combing_max_distance has no default_value!
[WARNING] JSON setting travel_avoid_other_parts has no default_value!
[WARNING] JSON setting travel_avoid_supports has no default_value!
[WARNING] JSON setting travel_retract_before_outer_wall has no default_value!
[WARNING] JSON setting retraction_enable has no default_value!
[WARNING] JSON setting retraction_count_max has no default_value!
[WARNING] JSON setting retraction_extrusion_window has no default_value!
[WARNING] JSON setting retraction_min_travel has no default_value!
[WARNING] JSON setting cool_fan_full_at_height has no default_value!
[WARNING] JSON setting cool_fan_enabled has no default_value!
[WARNING] JSON setting cool_min_layer_time has no default_value!
[WARNING] JSON setting adhesion_type has no default_value!
[WARNING] JSON setting brim_replaces_support has no default_value!
[WARNING] JSON setting skirt_gap has no default_value!
[WARNING] JSON setting skirt_line_count has no default_value!
[WARNING] JSON setting adaptive_layer_height_variation has no default_value!
[WARNING] JSON setting adaptive_layer_height_variation_step has no default_value!
[WARNING] JSON setting meshfix_maximum_resolution has no default_value!
[WARNING] JSON setting meshfix_maximum_travel_resolution has no default_value!
[WARNING] JSON setting support_angle has no default_value!
[WARNING] JSON setting support_pattern has no default_value!
[WARNING] JSON setting support_infill_rate has no default_value!
[WARNING] JSON setting support_use_towers has no default_value!
[WARNING] JSON setting support_xy_distance has no default_value!
[WARNING] JSON setting support_xy_distance_overhang has no default_value!
[WARNING] JSON setting support_z_distance has no default_value!
[WARNING] JSON setting support_xy_overrides_z has no default_value!
[WARNING] JSON setting support_wall_count has no default_value!
[WARNING] JSON setting support_brim_enable has no default_value!
[WARNING] JSON setting support_brim_width has no default_value!
[WARNING] JSON setting support_interface_enable has no default_value!
[WARNING] JSON setting support_interface_height has no default_value!
[WARNING] JSON setting support_interface_density has no default_value!
[WARNING] JSON setting support_interface_pattern has no default_value!
[WARNING] JSON setting support_interface_skip_height has no default_value!
[WARNING] JSON setting minimum_support_area has no default_value!
[WARNING] JSON setting minimum_interface_area has no default_value!
[WARNING] JSON setting top_bottom_thickness has no default_value!
[WARNING] JSON setting wall_thickness has no default_value!
[WARNING] JSON setting gantry_height has no default_value!
loading 'plato_geometrico1.stl' took 0.058 seconds
Loaded from disk in 0.086s
[WARNING]  -s mesh_rotation_matrix="[[1,0,0], [0,1,0], [0,0,1]]" -s mesh_position_z="0" -s mesh_position_x="0" -s small_feature_speed_factor="50" -s wipe_move_distance="20" -s wipe_hop_speed="10" -s wipe_hop_enable="true" -s wipe_pause="0" -s wipe_retraction_prime_speed="2" -s wipe_retraction_extra_prime_amount="0" -s wipe_retraction_amount="1" -s bridge_fan_speed_3="0" -s bridge_skin_density_3="80" -s bridge_skin_material_flow_3="110" -s bridge_fan_speed_2="0" -s bridge_skin_speed_2="25" -s bridge_skin_speed="15" -s bridge_wall_material_flow="50" -s bridge_wall_speed="15" -s bridge_skin_density="100" -s bridge_wall_coast="100" -s bridge_skin_support_threshold="50" -s bridge_settings_enabled="false" -s wall_overhang_speed_factor="100" -s wall_overhang_angle="90" -s adaptive_layer_height_threshold="0.2" -s adaptive_layer_height_variation_step="0.01" -s wireframe_nozzle_clearance="1" -s wireframe_up_half_speed="0.3" -s wireframe_flat_delay="0.1" -s wireframe_bottom_delay="0" -s wireframe_top_delay="0" -s wireframe_flow_flat="100" -s wireframe_flow_connection="100" -s wireframe_printspeed_up="5" -s wireframe_height="3" -s wireframe_enabled="false" -s flow_rate_extrusion_offset_factor="100" -s magic_fuzzy_skin_point_dist="0.8" -s magic_fuzzy_skin_outside_only="false" -s magic_fuzzy_skin_enabled="false" -s support_conical_min_width="5" -s support_conical_angle="30" -s cross_support_density_image="" -s max_extrusion_before_wipe="10" -s cross_infill_density_image="" -s cross_infill_pocket_size="2" -s coasting_min_volume="0.8" -s wireframe_strategy="compensate" -s coasting_volume="0.064" -s conical_overhang_hole_size="0" -s conical_overhang_angle="50" -s draft_shield_height="10" -s draft_shield_height_limitation="full" -s conical_overhang_enabled="false" -s draft_shield_enabled="false" -s wall_x_material_flow="100" -s skin_material_flow="100" -s skirt_brim_minimal_length="250" -s skin_no_small_gaps_heuristic="false" -s speed_wall_x="60" -s speed_wall_0="30" -s speed_infill="60" -s sub_div_rad_add="0.4" -s machine_feeder_wheel_diameter="10" -s infill_material_flow="100" -s wall_0_material_flow="100" -s material_no_load_move_factor="0.94086" -s jerk_wall_x="20" -s material_flush_purge_speed="0.5" -s support_tower_diameter="3" -s material_break_preparation_temperature="50" -s machine_steps_per_mm_y="50" -s jerk_travel="30" -s material_break_preparation_speed="2" -s adaptive_layer_height_variation="0.1" -s meshfix_extensive_stitching="false" -s wireframe_drag_along="0.6" -s material_shrinkage_percentage="100" -s material_surface_energy="100" -s machine_max_jerk_e="5" -s jerk_wall_0="20" -s material_print_temperature_layer_0="215" -s material_print_temperature="210" -s wireframe_printspeed_bottom="5" -s coasting_enable="false" -s ooze_shield_enabled="false" -s wipe_retraction_retract_speed="3" -s infill_before_walls="true" -s gradual_infill_steps="0" -s adaptive_layer_height_enabled="false" -s support_tower_roof_angle="65" -s machine_start_gcode="; Ender 3 Custom Start G-code
G92 E0 ; Reset Extruder
G28 ; Home all axes
G1 Z2.0 F3000 ; Move Z Axis up little to prevent scratching of Heat Bed
G1 X0.1 Y20 Z0.3 F5000.0 ; Move to start position
G1 X0.1 Y200.0 Z0.3 F1500.0 E15 ; Draw the first line
G1 X0.4 Y200.0 Z0.3 F5000.0 ; Move to side a little
G1 X0.4 Y20 Z0.3 F1500.0 E30 ; Draw the second line
G1 X5 Y20 Z0.3 F5000.0 ; Move over to prevent blob squish" -s machine_firmware_retract="false" -s infill_overlap_mm="0.04" -s outer_inset_first="false" -s raft_interface_line_spacing="0.9" -s infill_sparse_thickness="0.1" -s infill_offset_x="0" -s infill_angles="[ ]" -s zig_zaggify_infill="false" -s infill_support_angle="40" -s machine_extruders_share_heater="false" -s bottom_skin_preshrink="1" -s raft_surface_thickness="0.1" -s support_xy_distance_overhang="0.2" -s extruder_prime_pos_abs="false" -s top_skin_preshrink="1" -s adhesion_extruder_nr="0" -s skin_overlap_mm="0.02" -s skirt_brim_material_flow="100" -s speed_equalize_flow_enabled="false" -s mold_angle="40" -s infill_line_width="0.4" -s fill_outline_gaps="false" -s infill_wipe_dist="0.04" -s speed_topbottom="30" -s magic_spiralize="false" -s ironing_pattern="zigzag" -s ironing_only_highest_layer="false" -s wireframe_fall_down="0.5" -s default_material_print_temperature="210" -s wipe_repeat_count="5" -s infill_mesh="false" -s retraction_enable="true" -s skin_outline_count="1" -s roofing_material_flow="100" -s raft_surface_line_width="0.4" -s wipe_retraction_enable="true" -s speed_roofing="25" -s material_standby_temperature="150" -s infill_extruder_nr="-1" -s skin_angles="[ ]" -s ironing_monotonic="false" -s jerk_infill="20" -s top_layers="8" -s machine_width="235" -s roofing_layer_count="0" -s machine_always_write_active_tool="false" -s layer_height="0.1" -s machine_max_feedrate_x="2.99792e+11" -s material_adhesion_tendency="10" -s support_roof_line_width="0.4" -s machine_max_feedrate_y="2.99792e+11" -s meshfix_maximum_resolution="0.5" -s material_flow_layer_0="100" -s machine_nozzle_size="0.4" -s machine_heat_zone_length="16" -s ironing_flow="10" -s ooze_shield_dist="2" -s support_zag_skip_count="5" -s cutting_mesh="false" -s wipe_brush_pos_x="100" -s connect_infill_polygons="true" -s machine_endstop_positive_direction_y="false" -s roofing_extruder_nr="-1" -s gantry_height="1e+11" -s meshfix_maximum_travel_resolution="1" -s machine_extruders_shared_nozzle_initial_retraction="0" -s magic_mesh_surface_mode="normal" -s machine_minimum_feedrate="0" -s wall_line_width_x="0.4" -s machine_name="Creality Ender-3" -s material_bed_temperature_layer_0="60" -s machine_max_acceleration_e="10000" -s material_end_of_filament_purge_speed="0.5" -s support_bottom_height="1" -s machine_max_acceleration_y="9000" -s machine_show_variants="false" -s gradual_infill_step_height="1.5" -s machine_nozzle_temp_enabled="true" -s raft_smoothing="5" -s wall_min_flow="0" -s wireframe_top_jump="0.6" -s machine_steps_per_mm_z="50" -s machine_nozzle_cool_down_speed="2" -s material_anti_ooze_retracted_position="-4" -s material_bed_temperature="60" -s prime_tower_line_width="0.4" -s material_bed_temp_prepend="true" -s travel_compensate_overlapping_walls_0_enabled="true" -s material_print_temp_prepend="true" -s jerk_print_layer_0="20" -s machine_buildplate_type="glass" -s center_object="false" -s material_flush_purge_length="60" -s material_break_preparation_retracted_position="-16" -s xy_offset="0" -s carve_multiple_volumes="true" -s material_break_speed="25" -s infill_randomize_start_location="false" -s acceleration_skirt_brim="3000" -s acceleration_ironing="3000" -s extruder_prime_pos_z="0" -s jerk_ironing="20" -s retraction_extra_prime_amount="0" -s machine_heated_build_volume="false" -s support_bottom_line_width="0.4" -s wireframe_roof_drag_along="0.8" -s material_final_print_temperature="195" -s speed_slowdown_layers="2" -s skin_edge_support_layers="4" -s bridge_skin_density_2="75" -s machine_nozzle_id="unknown" -s layer_height_0="0.3" -s material_diameter="1.75" -s machine_max_acceleration_z="100" -s wall_0_extruder_nr="-1" -s retraction_hop_after_extruder_switch="true" -s material_flow_temp_graph="[[3.5,200],[7.0,240]]" -s machine_gcode_flavor="RepRap (Marlin/Sprinter)" -s top_bottom_pattern="lines" -s machine_nozzle_expansion_angle="45" -s material_bed_temp_wait="true" -s bottom_layers="6" -s machine_nozzle_heat_up_speed="2" -s material_break_retracted_position="-50" -s retraction_retract_speed="25" -s extruder_prime_pos_x="0" -s support_bottom_pattern="concentric" -s machine_depth="235" -s machine_nozzle_tip_outer_diameter="1" -s min_infill_area="0" -s machine_height="250" -s support_connect_zigzags="true" -s machine_extruders_share_nozzle="false" -s build_volume_temperature="0" -s initial_bottom_layers="6" -s brim_outside_only="true" -s min_skin_width_for_expansion="0" -s extruders_enabled_count="1" -s infill_line_distance="2" -s retraction_count_max="90" -s minimum_polygon_circumference="1" -s machine_end_gcode="G91 ;Relative positioning
G1 E-2 F2700 ;Retract a bit
G1 E-2 Z0.2 F2400 ;Retract and raise Z
G1 X5 Y5 F3000 ;Wipe out
G1 Z10 ;Raise Z more
G90 ;Absolute positioning
G1 X0 Y{machine_depth} ;Present print
M106 S0 ;Turn-off fan
M104 S0 ;Turn-off hotend
M140 S0 ;Turn-off bed
M84 X Y E ;Disable all steppers but Z
" -s skirt_brim_line_width="0.4" -s brim_line_count="20" -s bridge_skin_material_flow_2="100" -s support_conical_enabled="false" -s machine_nozzle_head_distance="3" -s material_break_temperature="50" -s optimize_wall_printing_order="false" -s speed_support_roof="40" -s support_roof_offset="0" -s material_extrusion_cool_down_speed="0.7" -s infill_pattern="grid" -s machine_steps_per_mm_x="50" -s material_maximum_park_duration="300" -s support_brim_line_count="20" -s machine_heated_bed="true" -s machine_use_extruder_offset_to_offset_coords="true" -s machine_max_feedrate_z="2.99792e+11" -s retraction_hop="1" -s machine_max_feedrate_e="2.99792e+11" -s travel_compensate_overlapping_walls_x_enabled="true" -s clean_between_layers="false" -s cool_fan_enabled="true" -s material_anti_ooze_retraction_speed="5" -s z_seam_type="sharpest_corner" -s raft_interface_line_width="0.7" -s speed_print_layer_0="30" -s raft_interface_acceleration="3000" -s machine_endstop_positive_direction_x="false" -s support_enable="false" -s bridge_skin_material_flow="60" -s speed_travel_layer_0="60" -s wireframe_roof_outer_delay="0.2" -s top_skin_expand_distance="1" -s speed_prime_tower="60" -s machine_endstop_positive_direction_z="true" -s default_material_bed_temperature="60" -s cool_min_speed="10" -s material_initial_print_temperature="200" -s layer_0_z_overlap="0.22" -s ironing_inset="0.35" -s flow_rate_max_extrusion_offset="0" -s acceleration_roofing="3000" -s alternate_extra_perimeter="false" -s gradual_support_infill_step_height="1" -s machine_max_jerk_xy="20" -s wall_line_width_0="0.4" -s bridge_sparse_infill_max_density="0" -s acceleration_enabled="false" -s slicing_tolerance="middle" -s machine_max_acceleration_x="9000" -s travel_avoid_distance="0.625" -s support_line_width="0.4" -s support_skip_some_zags="false" -s support_infill_angles="[ ]" -s speed_travel="120" -s support_bottom_material_flow="100" -s alternate_carve_order="true" -s cool_fan_full_layer="2" -s material_print_temp_wait="true" -s wall_line_count="2" -s wall_0_wipe_dist="0.2" -s top_bottom_extruder_nr="-1" -s support_material_flow="100" -s material_end_of_filament_purge_length="20" -s machine_acceleration="4000" -s wall_0_inset="0" -s machine_center_is_zero="false" -s smooth_spiralized_contours="true" -s acceleration_travel_layer_0="3000" -s skin_line_width="0.4" -s speed_z_hop="10" -s raft_interface_jerk="20" -s connect_skin_polygons="false" -s wireframe_roof_inset="3" -s cool_min_layer_time="5" -s raft_base_line_width="0.8" -s support_top_distance="0.1" -s machine_min_cool_heat_time_window="50" -s xy_offset_layer_0="0" -s z_seam_y="100" -s speed_ironing="20" -s z_seam_relative="false" -s jerk_skirt_brim="20" -s ironing_line_spacing="0.1" -s skirt_brim_speed="30" -s coasting_speed="90" -s speed_equalize_flow_max="150" -s acceleration_infill="3000" -s acceleration_wall_0="3000" -s acceleration_wall_x="3000" -s acceleration_topbottom="3000" -s infill_support_enabled="false" -s machine_shape="rectangular" -s support_bottom_stair_step_min_slope="10" -s acceleration_support_roof="3000" -s prime_tower_enable="false" -s infill_wall_line_count="0" -s minimum_bottom_area="1" -s raft_surface_jerk="20" -s material_crystallinity="false" -s multiple_mesh_overlap="0.15" -s acceleration_print_layer_0="3000" -s jerk_enabled="false" -s jerk_roofing="20" -s support_bottom_distance="0.1" -s raft_base_speed="15" -s support_offset="0" -s jerk_support_infill="20" -s support_supported_skin_fan_speed="100" -s jerk_support_roof="20" -s magic_fuzzy_skin_thickness="0.3" -s support_initial_layer_line_distance="2.66" -s jerk_support_bottom="20" -s jerk_prime_tower="20" -s speed_support_infill="60" -s ironing_enabled="false" -s machine_extruder_count="1" -s retract_at_layer_change="false" -s z_seam_corner="z_seam_corner_inner" -s machine_max_jerk_z="0.4" -s retraction_amount="6.5" -s retraction_prime_speed="25" -s retraction_min_travel="1.5" -s support_meshes_present="false" -s retraction_extrusion_window="4.5" -s acceleration_travel="5000" -s limit_support_retractions="true" -s bridge_wall_min_length="5" -s retraction_combing="all" -s retraction_combing_max_distance="0" -s support_bottom_stair_step_height="0.3" -s travel_avoid_other_parts="true" -s wall_x_extruder_nr="-1" -s travel_avoid_supports="false" -s layer_start_x="0" -s retraction_hop_enabled="false" -s retraction_hop_only_when_collides="false" -s retraction_hop_after_extruder_switch_height="1" -s cool_min_layer_time_fan_speed_max="10" -s ooze_shield_angle="60" -s cool_lift_head="false" -s fill_perimeter_gaps="everywhere" -s support_infill_extruder_nr="0" -s speed_support_bottom="40" -s support_extruder_nr_layer_0="0" -s skirt_line_count="1" -s filter_out_tiny_gaps="true" -s support_tree_branch_diameter_angle="5" -s raft_surface_line_spacing="0.4" -s top_bottom_pattern_0="lines" -s support_roof_extruder_nr="0" -s jerk_travel_layer_0="20" -s support_bottom_extruder_nr="0" -s support_structure="normal" -s support_tree_angle="40" -s wall_min_flow_retract="false" -s support_tree_branch_distance="1" -s support_tree_branch_diameter="2" -s support_roof_line_distance="0.4" -s wireframe_straight_before_down="20" -s meshfix_maximum_deviation="0.025" -s support_tree_collision_resolution="0.4" -s small_feature_speed_factor_0="50" -s support_type="everywhere" -s hole_xy_offset="0" -s support_angle="50" -s prime_tower_brim_enable="false" -s wipe_hop_amount="1" -s support_pattern="zigzag" -s bridge_enable_more_layers="true" -s support_wall_count="1" -s small_feature_max_length="0" -s draft_shield_dist="10" -s raft_interface_fan_speed="0" -s support_line_distance="2.66" -s support_brim_enable="false" -s raft_base_acceleration="3000" -s travel_retract_before_outer_wall="false" -s switch_extruder_prime_speed="20" -s initial_layer_line_width_factor="100" -s support_xy_distance="0.7" -s support_xy_overrides_z="z_overrides_xy" -s zig_zaggify_support="false" -s support_bottom_stair_step_width="5" -s remove_empty_first_layers="true" -s support_join_distance="2" -s acceleration_prime_tower="3000" -s support_infill_sparse_thickness="0.1" -s mold_width="5" -s gradual_support_infill_steps="0" -s jerk_topbottom="20" -s minimum_support_area="0" -s support_roof_enable="false" -s bridge_skin_speed_3="15" -s support_bottom_enable="false" -s support_roof_height="1" -s support_interface_skip_height="0.3" -s support_bottom_line_distance="0.4" -s support_roof_pattern="concentric" -s meshfix_keep_open_polygons="false" -s support_roof_angles="[ ]" -s layer_start_y="0" -s support_bottom_angles="[ ]" -s support_fan_enable="false" -s wireframe_roof_fall_down="2" -s print_sequence="all_at_once" -s support_use_towers="true" -s prime_tower_wipe_enabled="true" -s cool_fan_speed_min="100" -s support_tower_maximum_supported_diameter="3" -s cool_fan_speed_max="100" -s support_mesh_drop_down="true" -s prime_blob_enable="false" -s bottom_skin_expand_distance="1" -s extruder_prime_pos_y="0" -s adhesion_type="brim" -s bridge_fan_speed="100" -s skirt_gap="3" -s brim_gap="0" -s acceleration_support_infill="3000" -s meshfix_union_all_remove_holes="false" -s infill_enable_travel_optimization="false" -s raft_margin="15" -s prime_tower_position_x="200" -s skin_monotonic="false" -s cool_fan_speed_0="0" -s brim_replaces_support="true" -s raft_airgap="0.3" -s support_mesh="false" -s prime_tower_flow="100" -s raft_interface_thickness="0.15" -s raft_base_thickness="0.3" -s raft_base_line_spacing="1.6" -s wireframe_printspeed_down="5" -s z_seam_x="100" -s prime_tower_position_y="200" -s raft_surface_speed="20" -s infill_multiplier="1" -s raft_interface_speed="15" -s raft_surface_acceleration="3000" -s material_guid="" -s raft_base_jerk="20" -s raft_surface_fan_speed="0" -s wireframe_printspeed_flat="5" -s raft_base_fan_speed="0" -s minimum_roof_area="1" -s prime_tower_size="20" -s switch_extruder_retraction_amount="20" -s raft_surface_layers="2" -s prime_tower_min_volume="6" -s switch_extruder_retraction_speed="20" -s switch_extruder_extra_prime_amount="0" -s meshfix_union_all="true" -s infill_mesh_order="0" -s machine_steps_per_mm_e="1600" -s support_bottom_offset="0" -s mold_enabled="false" -s mold_roof_height="0.5" -s anti_overhang_mesh="false" -s relative_extrusion="false" -s support_roof_material_flow="100" -s roofing_line_width="0.4" -s acceleration_support_bottom="3000" -s roofing_pattern="lines" -s roofing_monotonic="false" -s infill_offset_y="0" -s roofing_angles="[ ]" -s mesh_position_y="0" -s material_flow_dependent_temperature="false" -e0 -s machine_extruder_cooling_fan_number="0" -s extruder_prime_pos_y="0" -s extruder_prime_pos_z="0" -s machine_extruder_end_pos_y="0" -s material_diameter="1.75" -s machine_extruder_end_pos_x="0" -s machine_nozzle_offset_y="0" -s machine_nozzle_size="0.4" -s extruder_nr="0" -s machine_nozzle_offset_x="0" -s machine_nozzle_id="unknown" -s machine_extruder_start_code="" -s machine_extruder_start_pos_abs="false" -s machine_extruder_start_pos_x="0" -s extruder_prime_pos_x="0" -s machine_extruder_end_code="" -s machine_extruder_start_pos_y="0" -s machine_extruder_end_pos_abs="false" -g -e0 -l "0" -s machine_extruder_cooling_fan_number="0" -s extruder_prime_pos_y="0" -s extruder_prime_pos_z="0" -s machine_extruder_end_pos_y="0" -s material_diameter="1.75" -s machine_extruder_end_pos_x="0" -s machine_nozzle_offset_y="0" -s machine_nozzle_size="0.4" -s extruder_nr="0" -s machine_nozzle_offset_x="0" -s machine_nozzle_id="unknown" -s machine_extruder_start_code="" -s machine_extruder_start_pos_abs="false" -s machine_extruder_start_pos_x="0" -s extruder_prime_pos_x="0" -s machine_extruder_end_code="" -s machine_extruder_start_pos_y="0" -s machine_extruder_end_pos_abs="false"
Progress: start accomplished in 0.035s
Starting slice...
Slicing model...
slice of mesh took 0.001 seconds
slice make polygons took 0.001 seconds
Progress:slice:1:1     0.018531%
Progress: slice accomplished in 0.007s
Starting layerparts...
Progress:layerparts:1:1     0.023922%
Progress: layerparts accomplished in 0.001s
Starting inset+skin...
Progress:inset+skin:0:100     0.023922%
Progress:inset+skin:1:100     0.026447%
Progress:inset+skin:2:100     0.028973%
Progress:inset+skin:3:100     0.031498%
Progress:inset+skin:4:100     0.034024%
Progress:inset+skin:5:100     0.036549%
Progress:inset+skin:6:100     0.039075%
Progress:inset+skin:7:100     0.041601%
Progress:inset+skin:8:100     0.044126%
Progress:inset+skin:9:100     0.046652%
Progress:inset+skin:10:100     0.049177%
Progress:inset+skin:11:100     0.051703%
Progress:inset+skin:12:100     0.054228%
Progress:inset+skin:13:100     0.056754%
Progress:inset+skin:14:100     0.059279%
Progress:inset+skin:15:100     0.061805%
Progress:inset+skin:16:100     0.064330%
Progress:inset+skin:17:100     0.066856%
Progress:inset+skin:18:100     0.069381%
Progress:inset+skin:19:100     0.071907%
Progress:inset+skin:20:100     0.074432%
Progress:inset+skin:21:100     0.076958%
Progress:inset+skin:22:100     0.079483%
Progress:inset+skin:23:100     0.082009%
Progress:inset+skin:24:100     0.084534%
Progress:inset+skin:25:100     0.087060%
Progress:inset+skin:26:100     0.089585%
Progress:inset+skin:27:100     0.092111%
Progress:inset+skin:28:100     0.094636%
Progress:inset+skin:29:100     0.097162%
Progress:inset+skin:30:100     0.099687%
Progress:inset+skin:31:100     0.102213%
Progress:inset+skin:32:100     0.104738%
Progress:inset+skin:33:100     0.107264%
Progress:inset+skin:35:100     0.112315%
Progress:inset+skin:36:100     0.114840%
Progress:inset+skin:38:100     0.119891%
Progress:inset+skin:39:100     0.122417%
Progress:inset+skin:40:100     0.124943%
Progress:inset+skin:42:100     0.129994%
Progress:inset+skin:43:100     0.132519%
Progress:inset+skin:45:100     0.137570%
Progress:inset+skin:46:100     0.140096%
Progress:inset+skin:47:100     0.142621%
Progress:inset+skin:49:100     0.147672%
Progress:inset+skin:50:100     0.150198%
Progress:inset+skin:51:100     0.152723%
Progress:inset+skin:53:100     0.157774%
Progress:inset+skin:54:100     0.160300%
Progress:inset+skin:56:100     0.165351%
Progress:inset+skin:57:100     0.167876%
Progress:inset+skin:58:100     0.170402%
Progress:inset+skin:60:100     0.175453%
Progress:inset+skin:61:100     0.177978%
Progress:inset+skin:62:100     0.180504%
Progress:inset+skin:63:100     0.183029%
Progress:inset+skin:65:100     0.188080%
Progress:inset+skin:66:100     0.190606%
Progress:inset+skin:68:100     0.195657%
Progress:inset+skin:69:100     0.198182%
Progress:inset+skin:70:100     0.200708%
Progress:inset+skin:72:100     0.205759%
Progress:inset+skin:73:100     0.208284%
Progress:inset+skin:74:100     0.210810%
Progress:inset+skin:76:100     0.215861%
Progress:inset+skin:77:100     0.218387%
Progress:inset+skin:79:100     0.223438%
Progress:inset+skin:80:100     0.225963%
Progress:inset+skin:81:100     0.228489%
Progress:inset+skin:83:100     0.233540%
Progress:inset+skin:84:100     0.236065%
Progress:inset+skin:85:100     0.238591%
Progress:inset+skin:87:100     0.243642%
Progress:inset+skin:88:100     0.246167%
Progress:inset+skin:90:100     0.251218%
Progress:inset+skin:91:100     0.253744%
Progress:inset+skin:92:100     0.256269%
Progress:inset+skin:94:100     0.261320%
Progress:inset+skin:95:100     0.263846%
Progress:inset+skin:97:100     0.268897%
Progress:inset+skin:98:100     0.271422%
Progress:inset+skin:1:1     0.276473%
Layer count: 198
Progress: inset+skin accomplished in 0.019s
Starting support...
Processing platform adhesion
Progress: support accomplished in 0.012s
Starting export...
Multithreading GcodeLayerThreader with 4 threads.
Progress:export:1:198     0.458613%
Progress:export:2:198     0.461359%
Progress:export:3:198     0.464106%
Progress:export:4:198     0.466852%
Progress:export:5:198     0.469598%
Progress:export:6:198     0.472345%
Progress:export:7:198     0.475091%
Progress:export:8:198     0.477838%
Progress:export:9:198     0.480584%
Progress:export:10:198     0.483330%
Progress:export:11:198     0.486077%
Progress:export:12:198     0.488823%
Progress:export:13:198     0.491569%
Progress:export:14:198     0.494316%
Progress:export:15:198     0.497062%
Progress:export:16:198     0.499808%
Progress:export:17:198     0.502555%
Progress:export:18:198     0.505301%
Progress:export:19:198     0.508048%
Progress:export:20:198     0.510794%
Progress:export:21:198     0.513540%
Progress:export:22:198     0.516287%
Progress:export:23:198     0.519033%
Progress:export:24:198     0.521779%
Progress:export:25:198     0.524526%
Progress:export:26:198     0.527272%
Progress:export:27:198     0.530019%
Progress:export:28:198     0.532765%
Progress:export:29:198     0.535511%
Progress:export:30:198     0.538258%
Progress:export:31:198     0.541004%
Progress:export:32:198     0.543750%
Progress:export:33:198     0.546497%
Progress:export:34:198     0.549243%
Progress:export:35:198     0.551990%
Progress:export:36:198     0.554736%
Progress:export:37:198     0.557482%
Progress:export:38:198     0.560229%
Progress:export:39:198     0.562975%
Progress:export:40:198     0.565721%
Progress:export:41:198     0.568468%
Progress:export:42:198     0.571214%
Progress:export:43:198     0.573961%
Progress:export:44:198     0.576707%
Progress:export:45:198     0.579453%
Progress:export:46:198     0.582200%
Progress:export:47:198     0.584946%
Progress:export:48:198     0.587692%
Progress:export:49:198     0.590439%
Progress:export:50:198     0.593185%
Progress:export:51:198     0.595932%
Progress:export:52:198     0.598678%
Progress:export:53:198     0.601424%
Progress:export:54:198     0.604171%
Progress:export:55:198     0.606917%
Progress:export:56:198     0.609663%
Progress:export:57:198     0.612410%
Progress:export:58:198     0.615156%
Progress:export:59:198     0.617903%
Progress:export:60:198     0.620649%
Progress:export:61:198     0.623395%
Progress:export:62:198     0.626142%
Progress:export:63:198     0.628888%
Progress:export:64:198     0.631634%
Progress:export:65:198     0.634381%
Progress:export:66:198     0.637127%
Progress:export:67:198     0.639874%
Progress:export:68:198     0.642620%
Progress:export:69:198     0.645366%
Progress:export:70:198     0.648113%
Progress:export:71:198     0.650859%
Progress:export:72:198     0.653605%
Progress:export:73:198     0.656352%
Progress:export:74:198     0.659098%
Progress:export:75:198     0.661844%
Progress:export:76:198     0.664591%
Progress:export:77:198     0.667337%
Progress:export:78:198     0.670084%
Progress:export:79:198     0.672830%
Progress:export:80:198     0.675576%
Progress:export:81:198     0.678323%
Progress:export:82:198     0.681069%
Progress:export:83:198     0.683815%
Progress:export:84:198     0.686562%
Progress:export:85:198     0.689308%
Progress:export:86:198     0.692055%
Progress:export:87:198     0.694801%
Progress:export:88:198     0.697547%
Progress:export:89:198     0.700294%
Progress:export:90:198     0.703040%
Progress:export:91:198     0.705786%
Progress:export:92:198     0.708533%
Progress:export:93:198     0.711279%
Progress:export:94:198     0.714026%
Progress:export:95:198     0.716772%
Progress:export:96:198     0.719518%
Progress:export:97:198     0.722265%
Progress:export:98:198     0.725011%
Progress:export:99:198     0.727757%
Progress:export:100:198     0.730504%
Progress:export:101:198     0.733250%
Progress:export:102:198     0.735997%
Progress:export:103:198     0.738743%
Progress:export:104:198     0.741489%
Progress:export:105:198     0.744236%
Progress:export:106:198     0.746982%
Progress:export:107:198     0.749728%
Progress:export:108:198     0.752475%
Progress:export:109:198     0.755221%
Progress:export:110:198     0.757968%
Progress:export:111:198     0.760714%
Progress:export:112:198     0.763460%
Progress:export:113:198     0.766207%
Progress:export:114:198     0.768953%
Progress:export:115:198     0.771699%
Progress:export:116:198     0.774446%
Progress:export:117:198     0.777192%
Progress:export:118:198     0.779939%
Progress:export:119:198     0.782685%
Progress:export:120:198     0.785431%
Progress:export:121:198     0.788178%
Progress:export:122:198     0.790924%
Progress:export:123:198     0.793670%
Progress:export:124:198     0.796417%
Progress:export:125:198     0.799163%
Progress:export:126:198     0.801909%
Progress:export:127:198     0.804656%
Progress:export:128:198     0.807402%
Progress:export:129:198     0.810149%
Progress:export:130:198     0.812895%
Progress:export:131:198     0.815641%
Progress:export:132:198     0.818388%
Progress:export:133:198     0.821134%
Progress:export:134:198     0.823880%
Progress:export:135:198     0.826627%
Progress:export:136:198     0.829373%
Progress:export:137:198     0.832120%
Progress:export:138:198     0.834866%
Progress:export:139:198     0.837612%
Progress:export:140:198     0.840359%
Progress:export:141:198     0.843105%
Progress:export:142:198     0.845851%
Progress:export:143:198     0.848598%
Progress:export:144:198     0.851344%
Progress:export:145:198     0.854091%
Progress:export:146:198     0.856837%
Progress:export:147:198     0.859583%
Progress:export:148:198     0.862330%
Progress:export:149:198     0.865076%
Progress:export:150:198     0.867822%
Progress:export:151:198     0.870569%
Progress:export:152:198     0.873315%
Progress:export:153:198     0.876062%
Progress:export:154:198     0.878808%
Progress:export:155:198     0.881554%
Progress:export:156:198     0.884301%
Progress:export:157:198     0.887047%
Progress:export:158:198     0.889793%
Progress:export:159:198     0.892540%
Progress:export:160:198     0.895286%
Progress:export:161:198     0.898033%
Progress:export:162:198     0.900779%
Progress:export:163:198     0.903525%
Progress:export:164:198     0.906272%
Progress:export:165:198     0.909018%
Progress:export:166:198     0.911764%
Progress:export:167:198     0.914511%
Progress:export:168:198     0.917257%
Progress:export:169:198     0.920004%
Progress:export:170:198     0.922750%
Progress:export:171:198     0.925496%
Progress:export:172:198     0.928243%
Progress:export:173:198     0.930989%
Progress:export:174:198     0.933735%
Progress:export:175:198     0.936482%
Progress:export:176:198     0.939228%
Progress:export:177:198     0.941974%
Progress:export:178:198     0.944721%
Progress:export:179:198     0.947467%
Progress:export:180:198     0.950214%
Progress:export:181:198     0.952960%
Progress:export:182:198     0.955706%
Progress:export:183:198     0.958453%
Progress:export:184:198     0.961199%
Progress:export:185:198     0.963946%
Progress:export:186:198     0.966692%
Progress:export:187:198     0.969438%
Progress:export:188:198     0.972185%
Progress:export:189:198     0.974931%
Progress:export:190:198     0.977677%
Progress:export:191:198     0.980424%
Progress:export:192:198     0.983170%
Progress:export:193:198     0.985916%
Progress:export:194:198     0.988663%
Progress:export:195:198     0.991409%
Progress:export:196:198     0.994156%
Progress:export:197:198     0.996902%
Progress:export:198:198     0.999648%
Progress: export accomplished in 0.611s
Progress:process:1:1     1.000000%
Total time elapsed  0.69s.
Gcode header after slicing:
;FLAVOR:Marlin
;TIME:20121
;Filament used: 12.1514m
;Layer height: 0.1
;MINX:36.056
;MINY:24.664
;MINZ:0.3
;MAXX:198.944
;MAXY:210.336
;MAXZ:20
End of gcode header.
Print time (s): 20121
Print time (hr|min|s): 5h 35m 21s
Filament (mm^3): 29227
I believe that maybe the problem is with the setting of the CURA_ENGINE_SEARCH_PATH variable. The truth is I'm still more of a mechanical engineer than a programmer, so most of the time I'm not entirely sure what I'm doing.
I have also tried with different settings in the command line but the result always missed some layers. Here are are the settings I've tried with:
/snap/cura-slicer/51/usr/bin/CuraEngine  slice -v -p -j /snap/cura-slicer/51/usr/share/cura/resources/definitions/creality_ender3.def.json  -o output.gcode  -s speed_print_layer_0=5 -s layer_height=0.2 -s speed_print=50 -s speed_travel=150 -s speed_infill=50 -s wall_thickness=0.8 -s speed_topbottom=25 -s speed_wall=25 -s speed_wall_0=25 -s speed_wall_x=25 -s skirt_brim_speed=5 -s acceleration_print=500 -s acceleration_enabled="true" -s acceleration_infill=500 -s  acceleration_wall_0=500 -s acceleration_wall_x=500 -s acceleration_topbottom=500 -s acceleration_travel=500 -s acceleration_travel_layer_0=500 -s acceleration_print_layer_0=500 -s retraction_speed=45 -s retraction_prime_speed=45 -s retraction_retract_speed=45 -s adhesion_type="skirt" -s skirt_line_count=3 -s skirt_gap=10 -s line_width=0.4 -l my_piece.stl
If anyone could provide me with some light about this issue.
By the way I know that there are a lot of posts related the same topics but to be honest the information wasn't straightforward enough for a mechanical engineer trying to deal with programs... xD.
So if anyone has a more detailed tutorial to work with the CuraEngine CLI it would be greatly appreciatted.
Thanks in advance.
    • 8 months later...
    Did you find a solution to your problem? I am also using creality_ender3 and even thought fdmprinter slices fine, creality_ender3.def.json possibly doesn't inherit properly from fdmprinter.
