On 10/27/2021 at 1:46 PM, LumcoMFG said:@CarloK It is a 1.7mm shift in the +Y direction, I believe (away from the front of the printer). Printer is running Firmware 6.5.2 and part was programmed in Cura 4.11.0.
I am currently running another print and am going to try manually loading material into the material station in the same bay to see if it has something to do with changing bays, but that somewhat defeats the purpose of the material station.
I apologize that it is not quite the same issue, I probably should have created a new thread.
CarloK 208
