How important is it to get rid of them? The solutions I know will make the print take much longer to print.
Do you care about how it looks or does it have to be water tight?
For both:
It appears they are happening at the z seam. These problems tend to occur at speed changes (in this case it stops and moves to the inner portion of your part or maybe this is the start of a layer). So you can reduce the speed change by printing slower. Much slower. Try 25mm/sec for ALL printing speeds (infill, shell, etc - I think there are 7 printing speeds).
Also keep other (non printing) speeds fast (travel speed, retraction speed) so there isn't time for the nozzle to leak (and then start up with less than ideal nozzle pressure).
Also make sure your wall thickness is a multiple of your line width - if line width is 0.37mm then wall thickness should be 1.11 or 1.48 (I prefer line width of 0.4 but 0.37 works fine).
For water tight:
Increase the line width to nozzle+20% so for a 0.4mm nozzle, try 0.5mm line width. And again, make all the printing speeds the same (40mm/sec should be slow enough). Make sure your wall thickness is a multiple of your line width. So if line width is 0.5 then wall thickness should be 1.0 or 1.5 (1.5 probably better for water tight).
You can even go as high as 1mm line width but if you do drop the speed by about 2X.
A year after the merger of Ultimaker and MakerBotQQ, we have unlocked the ability for users of our Method series printers to slice files using UltiMaker Cura. As of this release, users can find profiles for our Method and Method XL printers, as well as material profiles for ABS-R, ABS-CF, and RapidRinse. Meaning it’s now possible to use either Cura or the existing cloud-slicing software CloudPrint when printing with these printers or materials
gr5 2,094
For both:
For water tight:
