For things like this I would recommend settings optimised for mechanical strength, if it needs to survive real use.
I guess this would require supports to prevent sagging of the overhanging areas. But removing supports from the inside of tubing might be difficult.
Does it have to be a round shape? If not, a teardrop shaped tube, or diamond shaped, might print much better: it would be cleaner, stronger, and better watertight. Look at the cross section of the model in the center below, and imagine the whole tube having this rounded diamond shape (disregard the other models, this is an old picture from something else):
GregValiant 948
My printer is also an Ender 3 Pro.
That looks like it was printed without support. If you DID have support enabled - did you use a "Support Interface"?
If you use "File | Save Project" Cura will create a Project File with your printer, your settings, and that model. Post the 3mf file here.
