I was thinking in a similar direction like you, Jonny. But i was considering having the current setup from the back (straight ros and threaded rod) on each of the sides (omitting the one on the back), and coupling the two units, for example with a timing belt. i guess only to have the straight rods and bearings will be counter-effective. Since the bed is still only supported on the back, the front is still free to move. This will imho lead to canting in the front bearings.
If you had a rather stiff design, where two sides (or back and front) are controllled, you should be able to get a very rigid print bed.
On the other hand, you might get decent enough results if the arms were a bit higher, so the bearings get longer, resulting in a better angle to get the forces on the brint bed into the bearings.
drayson 74
Currently I´m working on stiffening the Z-table by replacing the two inner arms (which are holding the stage where the little black brackets for leveling are placed into) by 6mm aluminium arms.
Nevertheless, your approach is also very interesting!
