Seemingly dead Ultimaker 3
Darkstang5887
Posted · Seemingly dead Ultimaker 3
Hello. Hopefully someone can help me.
I bought a used ultimaker 3 about a month ago. I replaced the led light strips as they were turning yellow. Also replaced the front screen due to burn in. All has been well since with many prints successfully. Last night I turned the printer off, and now today it wont turn back on. I checked the following:
Made sure all cables were secure
Tested power supply for 24v
No signs of burn marks on white control board
Green led on white board and red led on olimex board come on
Tried plugging in a HDMI cable to my TV, nothing
Tried making a boot disk per gr5 instructions, nothing
Fan comes on for 3 seconds after switching power, but nothing else works, completely dead
I just ordered an olimex cable but not confident that will help anything
    Posted (edited) · Seemingly dead Ultimaker 3
    If you have the Olimex cable you can check. If the Olimex board boot. Your problem sounds similar to what I had.
    Edited by Siron
    I didn't read the text completely. And I ask a question that the answer also also in the are
    I received my olimex cable and I'm pretty certain I set everything up right using putty on windows 11. I get no read outs, similar to the no read out when HDMI is connected. I'm thinking the olimex board is dead. I bought this printer becuase I have hear the Ultimaker community is very helpful and engaging, but its been a few weeks and have only one response.
    Hi Darkstang5887
    Have you set the speed on  putty  115200 baud?
    Have you connectet the Cable the right way? The RX line  ( green Wire) to the tx connection on the Olimex board and tx line (Red wire) Rx connection.
    Have you check if you have 5V on the Olimex board?
    Did you try to start the printer with a unplugged wifi board?
    If you have already checked all this, it really looks like your Olimex board is defective.
    Hi @Darkstang5887,
    Did you really go through all the thing advised by @gr5 in this tread:
    Thanks
    Torgeir
    Just a follow up, after all my testing and following the guide from gr5, I came to the conclusion that my board was bad. Even the olimex cable could not connect to the board. After replacing the olimex board, the printer started up right away. Something happened to the board which I do not know but that was for sure the issue. Hopefully this helps someone in the future with a dead printer.
    • Like 2
