UlrichC-DE 122
8 hours ago, likl said:Same thing happens to me on my S5. Wondering why and how to lower the print bed so that I can remove the print safely.
I had that last time, too.
Normally, you would want to heat up the print core in this situation. For me, that didn't work. The option is disabled as long as a print part is on the printer.
When you say the print part is removed, it makes reference run and rips out the rails.
So better you try to remove it manually.
Edited by UlrichC-DE
likl 0
