Is this stringing due to moisture?
sjstein
Posted · Is this stringing due to moisture?
Below is an example print from my S5, AA 0.8 core, using the Ultlimaker Nylon material - pretty much fresh from a new package.
Perhaps I'm too naïve when it comes to nylon, but I was hoping that the default settings in (the most recent) Cura and S5 firmware, coupled with a new package of material would yield decent prints. However, as you can see, this print is a bit of a mess.
For reference, the Cura settings I used were the default for a "fast" print:
AA 0.8 core
0.2mm Layer height
20% infill (triangles) (likely no infill was used in this smallish piece)
245 deg C print temp
70 deg C plate temp
35mm/s print speed
Retraction enabled
Print cooling enabled (fan speed 40%)
Brim adhesion
Despite this being a new spool, do I need to dry it out? I don't really think using my oven at home is a good idea, so are there other practical options?
        How to Enter
        Design an Ornament
          Entering a new design
        Entering an existing design
        Winning designs should:
        Be original Creations
        Good luck 🎉
        • 1 reply
        • 14 replies
