1 hour ago, UlrichC-DE said:Yes ASA is a devil's stuff and the printcore is history.
For the ASA on the flap, a pair of pliers and a hot air dryer will help. I would try to exert as little force on the flap as possible. If the something is bent, the closing of the flap no longer works.
I would put the plate in a vise. Then I would use a hot air gun to heat the plate and pull out the print core at the same time.
Wish you much success and also some luck!
Thanks! I was able to get it out with a vise. The printcore is indeed ruined, as is the capacitive sensor. Looks like I'm in for about $250 worth of replacement parts, but the other printcore and the rest of the head was undamaged, thankfully.
1
UlrichC-DE 108
