How to use PET from ICE , not possible to send sliced file to ultimaker 3 via wifi as he does not recognise material
Posted · How to use PET from ICE , not possible to send sliced file to ultimaker 3 via wifi as he does not recognise material
Dear,
I have PET  blue transparent from ICE , In Cura I used Tqulman T-glase profile to slice the part. It sliced and mentioned file successfully send to Ultimaker 3.
On the Ultimaker, I can't  choose PET so i loaded the PET as PETG.
The Ultimaker does not react on the send from Cura, I tried a few times. Sometimes it mentions it receeived a file but when pressing ok, nothing happens.
I guess it looks for the ID chip on the filament roll or whatever....
I  can only start the print by putting it on a usb stick and select it at the printer from usb stick, then it mentions material not same as defined, stop or ignore.
By ignoring it starts the print finallly.
But: I can;t send the fiel over wifi ??? in this case ??
Best Regards
Alex JAspers
Jtronicx
