First realize the front fan only comes on when either core is above 60C (or 40C and a core is turned on).
Here's the relevant part of the schematic of the UM3 print head circuit board. All 3 circuits use the same electronics and all 3 put out 0V and 5V.
I'm guessing Q1 has failed. That part can get pretty hot. I'd just order a new print head board. Although if you are really good with surface mount soldering you could test the voltage at the base of Q1 (should be around 0V when fan is supposed to be off and around .7V when the fan is supposed to be on). It could be that the emitter is broken (pin going to ground) and the fan is powered from the previous circuit through that 330 ohm resistor. The fan gets 5V and 0V power separately from the other inputs (although maybe the fans don't use that second ground?) Normally if things are working, when the fan is off the top of Q1 is about 5V and when the fan is on the top of Q1 is approximately 0.2V.
Awesome! Thanks for this info, it looks like that's exactly what happened. I ordered a new board for the head and will keep you posted if that fixes it!
Thanks!
1
A year after the merger of Ultimaker and MakerBotQQ, we have unlocked the ability for users of our Method series printers to slice files using UltiMaker Cura. As of this release, users can find profiles for our Method and Method XL printers, as well as material profiles for ABS-R, ABS-CF, and RapidRinse. Meaning it’s now possible to use either Cura or the existing cloud-slicing software CloudPrint when printing with these printers or materials
gr5 2,094
mylespol 1
Thanks!
