Ok makes sense to do a factory reset. I'm still a newb and was totally unsure what to do so thank you.
Will adjust the z stop and check the wiring on that also.
I have tried to look up how to do a reset for an issue with my first printer, which worked for a year, but got frustrated and just bought this one. I guess I really need to learn that and maybe I can use my old one again too.
Thank you again, very much appreciated
GregValiant 1,145
I have no idea what might have happened to cause all that. There are some basic things to check.
Check the Z switch and it's wires. When the X beam lowers it should hit the switch and the switch tells the processor it can stop moving the Z. You can take the build plate off or raise the Z switch and try to get the Z stop function working without smashing up the machine.
If the Z switch is faulty then you can try swapping it with the X or Y switch (they are often the same model switch).
Going beyond that there are things like a firmware factory reset, but really, the X beam shouldn't be able to go low enough to drive the nozzle into bed. That's the whole purpose of the limit switch there.
The Auto-Home routine is a macro in the printer memory. The speeds and so forth are in there as settings and the Z should move slowly. If it isn't moving at like 10 or 15 mm/sec then maybe it is a firmware glitch. To perform a factory reset - write down your personal settings (Home Offsets, PID, steps/mm, etc.) and then send M502 (or print a one line gcode file consisting of M502) and then re-enter your personal settings and then Save Settings on the LCD. It might make a difference.
When one problem is camouflaging another then that second (or third) problem down can be tough to locate.
