Thanks for the reply.
You mean that selecting the material on the printer upon inserting it, is what is meant to set temperature? But what if you have two brands of PLA, which you want to print at different temperatures?
I suppose selecting "Marlin" implies that I need to flash the firmware of the printer?
Edited by gauthier
ahoeben 1,723
This is "by design". For the Ultimaker 2 family, you set the material on the printer, so the printer sets the temperatures. Also note the small exclamation marks in front of the checkbox. They have a tooltip.
If you would rather control everything from Cura, go to the Printers pane of the preferences, click the Machine Settings, and change the G-code flavour from "Ultimaker 2" to "Marlin". Personally I think that is the better workflow.
