What you are measuring is the net force on the free end of the load cell.
Like you said, to fully eliminate it, you have to setup up some kind of despooling system. Maybe a photogate that activates a motor when the beam is broken by the filament. Alternatively, an arm that is moved by the filament, and increasing the despooling rate as the arm is is moved. Alternatively, a sufficient amount of filament could be despooled ahead of time.
aviphysics 9
