Ive never had this issue exporting out of autodesk inventor. but i cant upload the ipt here. for some reason i think it thinks the sections are detached from another
GregValiant 1,119
I use Inventor's predecessor Mechanical Desktop. Occasionally, when I perform a Union the pieces aren't exactly surface to surface. It's really hard to see in the CAD software but a slicer will notice that and create a boundary at what it deems to be a gap, or will end up with a gap where there should be a seam. If you go over the model and check your sketches and constraints and any suppressed features then you may find the problem.
So from what I've been able to see, the model slices exactly as it should but not as you intended.
1
GregValiant 1,119
I opened the model in MS 3D Builder. There are errors in the model that the program was able to correct.
The center section is almost like a separate model. There is a top surface and a bottom surface on the interior and that's why Cura is filling it with infill. I think that Cura is working as expected.
This is the repaired model and it clearly shows that there are three sections to it.
and here it is with PrusaSlicer (which called the model "unprintable").
