There should be a "next error" button where you click the button and it zooms and centers the view on the next internal plane.
That would be awesome - but probably also take considerably more effort to implement. Simply counting the red planes can maybe be done by actually counting every time the renderer draws a red surface, and then showing the counter on the screen.
But as I already said - I don't know the program code so I leave that up to the programmer
The holes are a different story...
My "routine" is: Check for red stuff (which takes a lot of time that can probably be reduced without much effort), then check for holes with layer view.
It would be nice if any "ignored geometry" (because it's thinner than the nozzle) could also be highlighted in another color. But that's a much bigger feature request than what I intended...
gr5 1,872
However be aware that you can also have "holes" in your model - like tiny windows where two edges don't quite meet up. I am only able to detect these in layer view where it won't fill a particular layer due to a windows over on the side. Cura can't detect these because it's hard to tell if the holes are on purpose.
