I did another test today to see how sensitive the current control is to the temperature. The quick answer: temperature doesn't seem to affect the current control for the extruder stepper.
First I tested with it set to 500ma mode (weaker than normal). I prefer to do it at weaker than normal because that way I am less likely to grind the filament. I used the same test setup as before although I zeroed the scale this time when the bungee's were mostly loose but the extruder was holding the weight of the vice grips. It was an arbitrary zeroing.
I also pulled the board off the bottom of the machine and twisted it so I had access to the back side. I measured temperatures with a infrared temp probe (doesn't touch the board).
I did multiple tests at each of 3 temperatures:
28C 536g 540g 544g
-5C 558g 550g
40C 560g
Notes about the temperature:
28C: initial temperature when I started measuring. Aiming at resistors I got 28C aiming at chip I got 30C.
-5C: used freeze spray to get it to probably -20C but by the time I finished two tests and measured temp it was warmed up to 5C.
40C: used heat gun - probably heated to a little warmer than 40C - maybe 45C but by the time the test was over it had cooled to 40C
Measurements were made in the order shown above. In other words the 40C test was done last.
These pulling strengths - around 1/2 kg aren't the full amount pulled. Unfortunately I walked away and lost where my zero point was but it was already pulling about 900g (very very rough) so the total pull strength was maybe 1.4kg which conflicts with my earlier graph I believe which pulled closer to 2kg but the 900g is not accurate.
Nicolinux 288
Just for reference. Here are the filament bits. The one on the left was ground down.
Oh and hat tip to Sigi. He had suggested to move the knurled bolt mantle down.
