thanks for the reply, i just read the exact same post but unfortunately i have allready disconnected the jumper.
changing the zsteps to the double value with the ulticontroller did the trick so far, its the exact same size as in cura.
so i will leave it at that, i am just curious what it could be...
IRobertI 517
This is usually caused by incorrect jumper settings. See this post:
http://umforum.ultimaker.com/index.php?/topic/4128-um1-z-axis-is-12-of-original-height-solved/&do=findComment&comment=34567
