I copy and pasted all the related files that it saved from 4.11 into 4.12 and the printer doesn't appear as a printer in Cura, but I get no error messages either.
However, I was able to modify the .json files to add a second extruder. I had failed to notice the commas when copy and pasting pieces from working definitions and have gotten my printer to print using Octoprint, I haven't messed with it enough to say whether this is required.
Thank you for your help, I did look back at the previous discussions and learned about a different dreamer profile which didn't seem to work for me. It also showed me that I had used too specific of keywords when searching about this issue previously.
GregValiant 956
Printer definition files tell Cura how to set up for the particular machine. If a printer has multiple extruders it must say so in the definition file and then in the Extruders folder there must be an extruder definition file for each possible extruder. If you have copied your Flashforge definition file into Cura's "resources\definitions" folder then go into the 4.11\resources\extruders" folder and copy the FlashForge extruder files into the correct folder in the new version of Cura. One file might be "flashforge_dreamernx_extruder_0.def.json" and the second might be "flashforge_dreamernx_extruder_1.def.json".
This has come up before around here. If you search for FlashForge on this forum you will find what other people have done.
