DivingDuck 85
You should be careful to not mess up Cura's configurations files until you really know what you are doing. There are always more than one file in a printer definition involved.
Delete the configuration folder for 4.12 and 4.13. Make a backup of these folders (just in case) before doing so. You will find them here:
c:\Users\YOUR_USER_NAME\AppData\Roaming\cura\
where YOUR_USER_NAME is your Windows user name.
With the next start of Cura the directory will build new. You may need to do your printer setup in Cura again.
nuno8210 3
Same problem here. It worked fine, but today I tried to open a file and it shutdown just after opening Cura. Uninstalled and re-installed verion 4.12.1.
Already rebooted PC, added "Printjob Naming plugin" from marketplace, tried to remove printer com cura.cfg and delete cura.cfg... Can't slice anything with Cura!!! Any help?
