Hi @munsee, have you checked out our e-learning platform that also contains the unboxing and setting up of your Pro Bundle? If you haven't yet, check it out here!
Oh, I realise now that you probably mean on the setup wizard on the printer. Then @UlrichC-DE is right. In any case, still worth to check out some courses if you are just embarking on your 3D printing journey!
UlrichC-DE 107
Hello,
I think a firmware reset will reset everything. Then you can start again from the beginning.
Many greetings
