Well i just tried and it's a 3mf file that had the embedded image so i'm pretty sure it saved with 4.13.1. So you're telling me, start/endcode settings that may have changed since the project was created get overridden and i have to redo them all? That shouldn't be happening. I don't mind the sidebar stuff getting overridden, that's the job. But start/end gcode shouldn't get replaced
16 hours ago, Ch3vr0n said:That shouldn't be happening.
Well, that's how it works in Cura. Cura can't read your mind and know what settings you do or don't want to load from the project. It would be nice if you could select from a list of options which (sets of) settings you want to load from the project when loading a project.
It probably does ask, but with limited choice. I'm guessing the first "dropdown" when you open is for the startcode as it asks if you want to update the printer or add a new one. But there's no way to select to KEEP the current one
4 minutes ago, Ch3vr0n said:I'm guessing the first "dropdown" when you open is for the startcode as it asks if you want to update the printer or add a new one.
You are guessing incorrectly.
Loading settings from projects is currently "all or nothing". It would be nice if there were options to eg keep the current preferences, what settings are visible, and the machine settings. There are no such options. The whole state of the application is imported from the project file. All that dropdown does, is letting you select what "printer instance" these settings are loaded in to; you can have multiple of the same printers configured in Cura.
ahoeben 1,589
Are you perhaps loading old projects? Projects contain all settings, including start & end gcode.
