I see this notice on .STL files from Blender 3.1 but not Blender 2.7.
It happens in Cura 4.11 and 4.13.
The prints are the right size.
I'm using the Blender Mesh-3D-Print add-on in both 2.7 and 3.1.
Puzzling!
Puzzling!
Maybe this solves it.
I had forgotten to set up the default file in mm when I updated to Blender 3.
This excellent tutorial from Maker Tales shows how.
Blender_Setup_In_mm
https://www.youtube.com/watch?v=R-Vq2O-hvfo
ahoeben 1,586
Coordinates in STL files don't have a unit. Cura assumes the unit is mm, but if Blender put your models with a different unit scale in the file, then there is no way for Cura to know this. I am not familiar enough with Blender to tell you what unit Blender assumes for an STL if you change the unit for the scene from m to mm. From what happens I think it converts the units back to meters upon export.
The Mesh Tools plugin (see the Marketplace) has an option to scale models from "unitless filetypes" such as STL upon load. It will do this in a way that the model ends up bigger (or smaller), but still at 100% (ie: it actually scales the coordinates). Alternatively you can apply the scale in Blender in the export to STL dialog.
Aymi1 0
I have applied the scale, and I have also tried changing the blender properties to m instead of mm, but I still get the same scaling event.
I'm not sure how to give the STL in the correct size then, as the file was from the ground up built in mm, exported in mm, and is saved in mm.
Very confused as to the cause and have not been able to find a sufficiently helpful answer to how to solve this =(
