A nice idea for the kids is the Minecraft import, buildin by Cura. My son just printed his building from minecraft. Building in minecraft is simple but the overall result you can get is quite attractive. You do need to run Cura on the computer that also runs minecraft. So in my case I installed Cura on his computer edited the settings and now he can do it again if he wants to.
kerry 0
I've been using Cubify Invent for the past couple of years. It is paid software, but US $49 is not terrible considering the functionality. I use the history extensively. I'm not sure what the nomenclature is for the feature, but it saves every step individually in the process of building your model. If you found that a hole you made in step two is too small, you can go to the step and change it. The remaining steps are still valid. This feature alone is worth the money to me, especially when I am doing iterations on a design.
