Ok, well, it shouldn't move a whole lot considering the tolerances
But it shouldn't be an issue I think as long as it's the plastic thingy that is moving it rather than due to huge friction against the filament. But like I said, when using just normal PLA I don't use the guide at all. But it's up to you
Regarding the filament change. I don't use the built in material change routine at all. I let the head cool down to about 90-100C before pulling out the filament so that it completely empties the head in one shot. That way whatever colour you change to will be pretty much completely pure right away. This is especially useful when changing from something like red to white. With even a tiny bit of red left in the head it will take a while for the white to be truly white.
Top Posters In This Topic
120
118
52
37
Popular Days
Feb 10
33
Feb 25
29
Feb 13
26
Mar 27
23
ian 120 posts
IRobertI 118 posts
Blizz 52 posts
geeks 37 posts
Popular Days
Feb 10 2014
Feb 25 2014
Feb 13 2014
Mar 27 2014
Posted Images
cyan 0
Great, exactly what I was looking for. Don't want to cross post, but it turned out nicely, easily managed 10mm3/s, didn't really seem like it was even trying, although I'm getting horrible ringing even at quite slow speeds:
http://umforum.ultimaker.com/index.php?/topic/4586-can-your-um2-printer-achieve-10mm3s-test-it-here/?p=49786
Thanks to everyone working on this issue and chasing all the components of the problem. The geek in me wants to find a way to test each component in isolation, and maybe build up a flowchart of checks that be applied to figure out the root cause of any particular under extrusion problem. If anyone has ideas in that direction and I can help, let me know.
