+1 to what Pm_dude said, plus I'd say to use 100% fill. You want it doing the same thing on every layer so that the only variable is your tweaks. I would start off fairly light then tighten until you can just see indentations being pressed into the filament as it feeds. Then tighten a quarter turn at a time until you like the printed result.
I've found that I can tell by the knurled indentations on the filament if it's being squeezed the right amount.
Top Posters In This Topic
120
118
52
37
Popular Days
Feb 10
33
Feb 25
29
Feb 13
26
Mar 27
23
ian 120 posts
IRobertI 118 posts
Blizz 52 posts
geeks 37 posts
Popular Days
Feb 10 2014
Feb 25 2014
Feb 13 2014
Mar 27 2014
Posted Images
pm_dude 27
I have the sprint compressed to about 13mm long when the arm is loaded and a filament is present.
Try printing a small cylinder (like a coin) about 25mm wide and 5mm tall. While printing you should be able to tweak the tension untill you are happy with the result.
