xstrand is on the marketplace - it's GF (not CF) but it's the best filled filament I've ever tested (only tested about 5 and haven't tested any in the last 3 years or so).
The profiles are overrated in my opinion. If you are printing PA6 or Nylon filled filaments (CF or GF), then just use any generic nylon profile. But definitely use the CC 0.6 core.
1
gr5 2,071
That's a polypropylene filament. aka pp. That's probably the hardest thing to get to stick to glass.
UM recommends adhesion sheets so you could try that. They sell them. I've tried PP on adhesion sheets and it works just fine but I tore the sheets every time so it's a LOT of work putting them down, removing bubbles, then removing the sheets after removing the print (if they tear) (or print on a different area).
Alternatively you could try "magigoo pro pp". My 3d printing buddies swear by magigoo. I've never tried it but I hear good things.
I try to avoid PP wherever possible since there are so many alternative filaments with CF or GF (nylon is my favorite but there are petg/cpe alternatives, polycarbonate, abs (yuck - stinky)). PP does have a few nice properties. I think in particular it's more chemical resistant.
Pedrones 0
Oh goshh I didn´t about this downside of PP... Anyway I´ll try both options, thanks a lot for that! I am curious about which other CF or GF filaments do you use. Actually I chose Braskem FL900PP CF because it was the only CF option available on the marketplace.
