Thanks for reply. Ya, I could do that, and also reduce z height accordingly under printer limits to be sure no issues, but thought it would be neat if it could handle the logic…maybe in future….
GregValiant 1,112
My printer lists a Zmax at 250. I didn't like the way the bowden and cables were bent when it's that high so I lowered it to 240 in cura. I can still use the 250 if I need it. I go back into Machine Settings and move the height back up for just that print. It doesn't happen often (I think once for me).
There is a slicer (PrusaSlicer?) that does math in the StartUp and End gcodes but I'm not sure if it can do logic.
Yes thanks...I also use Prusa Slicer and that is where I got the idea from. Wanted to use with Cura as well if that was possible....but I guess it isn't.
GregValiant 1,112
It does not support logic or math in the Start or End gcodes.
Unless your prints are always at max height you can use a relative move of 5 or 10mm's to get the nozzle off the print.
