But it seems like Cura wants to pull in certain Digital Factory settings. It is also duplicating each normally connected printer as a "cloud" printer as well so my list essentially has a full set of duplicates. Some features (camera) are available on the cloud if the "cloud version" is selected, yet you can't tell which on is a "normal connected" printer and which one is a "cloud" printer until you select it and then see the tiny blue and white icon at the corner of the name.
I think I will be dropping Digital Factory asap.
jsw 15
I see them as two separate applications.
Cura is the slicer, a stand-alone application that runs on a PC, and Digital Factory is the web-based application that runs on the printer.
