Setting split middle line threshold to 50% definitely cleaned up the preview, changing add middle line threshold didn't appear to make a difference so I left it at 94%
GregValiant 983
When you have features on a part that require an out-and-back movement (your gear teeth, tines on a comb or rake) then that setting comes into play. At 50% the nozzle extrudes while outbound and while inbound then moves to the next tooth. At 75% (or whatever it was) Cura decides on a single out extrusion, jumps to the next tooth, and then a single extrusion coming back towards the hub. Not at all what you want on that model.
On a small detailed model like that I would think a .4 or even a .3 nozzle would be a better choice. The line width can be smaller than the nozzle size but there is a point where things start to break down and a smaller nozzle is in order. With the .5 nozzle the teeth don't really have the correct profile. With a .3 nozzle they look like gear teeth.
Edited by GregValiant
GregValiant 983
Hello @krona. With the model loaded in Cura use the "File | Save Project" command and post the 3mf file here. With the changes in 5.0 you will need to revisit your settings. Off the top of my head I'd say it looks like your line width is too much for the teeth. If you are at .5 line width try dropping it to .45 and see if the preview gets better.
Enabling "Print thin walls" may help as well.
Two other settings that didn't exist in 4.x are "Split middle line threshold" and "Add Middle Line Threshold". Try setting them to 50%. They can effect long thin features and how may passes the nozzle makes to print them.
krona 0
Pinion22t.3mf
