GregValiant 1,112
What I tried to say is that in many model file formats (like STL) the models are glued together and effectively there is only a single model in the file even though there may be space between the pieces. They don't come in as separate models because they aren't separate models. That isn't a Cura thing, but a "translator / exporter" thing.
GregValiant 1,112
It depends on the model file. If the models don't line up in the Z in the file, then they won't line up when you open the file in Cura.
There is a plugin in the MarketPlace called Mesh Tools. One of the tools is "Split Model into Parts".
If I "union" multiple parts in the CAD software and then export the model as an STL I can use the Split Model tool in Cura to convert them back into separate pieces. Then if they were misaligned in the Z (I've done that) or I simply don't like the way they are arranged - I can move the individual parts so they are each on the build surface and rotated into position the way I want. 3MF and other model file types?...I don't know. After re-aligning the parts, they can be grouped together again and moved as an assemblage.
When you select a model in Cura, sometimes the "ungroup" and "unmerge" tools will be available in the right click menu. If they are then they might be able to split the agglomeration of pieces into single models.
If a model is part of a group then in Windows "CTRL+LeftClick" will pick a single model from within the group.
So all of that sort of depends on the file format you are bringing in to Cura and how the export utility created that file in the first place.
Johnmgg 0
I will try it but seems complicated and the designers of CURA 5.0 need to come up with a simpler procedure. This just takes to much time for what should be a simple and easy process.
