I am use Arachne version, beacuse in standard Cura i cant print thin walls. In Arachne all ok with thin walls
And have you set the Z-Seam to a fixed position?
The Arachne was the beta version of Cura 5, so could be that when there was a bug that it is fixed in Cura 5. But not sure if this is a bug or not.
- 1
Arachne has been merged into Cura 5. There will be no more Arachne builds, but Cura 5 will get continued development. Use Cura 5 now, instead of the Arachne test builds.
It looks like this is a known issue with Cura 5 (and Arachne before it):
Smithy 1,144
Do you use the latest Cura 5 or still the Arachne Beta?
