GregValiant 1,112
The "Support Blockers" can be configured in different ways. The normal situation is to block support (Duh!!). The tool above the Support Blocker tool provides the "Per Model" settings and one of them is "Modify settings for overlaps".
Since a support blocker is just another mesh (and can be scaled and moved like any other mesh), you can configure them as "Infill Mesh" (which you want for changing the infill) or as a "Cutting Mesh" (which gives different possibilities). Below is an image with the Support Blocker configured as "Infill Mesh" and I've added "Infill Density" and "Infill Pattern" as two of the settings changing them to 25% and Gyroid. Within the overlap of the block with the part you can see that the density and infill type is different.
Edited by GregValiant
Mikelo 0
Hello Hajm, I was looking for information on this topic and I guess we have a similar problem:
Problem with filling of concrete parts Sorry, I'm Spanish, let's see if someone can guide us.
