Posted · Cura 5.0 - Walls printing order not optimized
Hi all,
I am comparing the same object (ofc) and the same settings (theorically) but i have noted some bad differences in cura 5.0
here are my walls settings:
and here is a short video to show you what i mean: https://streamable.com/shgi0s
(on the left cura 5.0 - on the right cura 4.1.2)
1) 0:11 sec: cura 5.0 slice 1 inside wall and then 1 outside wall
2) 0:17 sec: cura 5.0 probably randomize the wall start for each single wall instead raomizing at layer change (same at second 0:23)
3) 0:32 sec: cura 5.0 makes 2 circle of infill around the inner peremiter ???
4) 0:41 sec: cura 5.0 makes 2 circle of infill around the outer peremiter ???
5) 1:00 min: cura 4.1.2 as it should work
Thanks 🙂
