GregValiant 1,112
Hello.
The gray areas are likely for the "Build Plate Adhesion". Only the Ender 3 has disallowed areas for the clips of the glass bed and they are only along the front edge and rear edge.
If you change your adhesion to "Skirt" with the Skirt Line Count = 1, and Skirt Distance = 1mm then those gray areas should get smaller and the model should fit. If you set the Build Plate Adhesion to "None" then the gray areas should disappear altogether.
DivingDuck 94
Sorry, I can only post in english.
There was never an official Ender 2 pro setup available. The Ender 2 profile was introduced by an user as "Creawsome Base Printer" and the first version for Ender 2 (not Ender 2 Pro) some when back in 2019. Since then the bed size was set to 150 x 150 and 200 mm tall. The real bed size was 165 x 165 and 210 in height.
Your printer have according Creality documentation for Ender 2 Pro a bed size of 165 x 165 and the height is 180 mm.
To match this with your profile you can change the bed size and height.
-->Preferences -->Configure Cura -->Printers, select your printer -->Machine Settings
Modify the values to your need like X=160 , Y=160 and Z=180. This will give you 10 mm more in X and Y and leave a margin of 5mm.
Attached picture is an example for a modified Ender-2 profile.
