I did something similar to this yesterday, with a wire thin enough to fit through the nozzle; after removing the bowden tube i could get a big chunk of insanely hard PLA out of there, probably filled with contaminations. Tho it didnt help much in the end...
Ill try the cold pull once today, and see how it goes!
Ultimaker 2 extruder always skipping; even at highest tension.
3 hours ago, stu_le_brew said:I think the likely cause is some small blockage or constriction in the print head, so you should try cleaning the nozzle using a length filament and by heating the print head (maybe higher than normal -even up to 230 degrees) then allow the head to drop just below 100 and pull out the filament - this usually removes any constriction, you may want to do this more than once.
good luck
ok, i instantly find a problem; the extruder still skips with the bowdentube+filament out of the printhead...
1 hour ago, SlinkySlonkyWoffle said:ok, i instantly find a problem; the extruder still skips with the bowdentube+filament out of the printhead...
And i found the solution to that, my out-of-frustration highest tension for the extruder was too much for the filament i am using, putting it to the middle resolved this issue...
just wondered which extruder feeder your UM2 has - is it white or black, black being the older and weaker in terms of torque
The mid position is usually correct for either feeder.
Just for your info I have been using a Bondtech geared extruder feeder form many years with some really good results, It was first available before Ultimaker came out with the upgrade to the white feeder. I would never go back
On 7/10/2022 at 2:22 PM, SlinkySlonkyWoffle said:I did something similar to this yesterday, with a wire thin enough to fit through the nozzle; after removing the bowden tube i could get a big chunk of insanely hard PLA out of there, probably filled with contaminations. Tho it didnt help much in the end...
in my first reply I did say to use filament to clean the inside of the nozzle, as any contamination inside the nozzle will stick to filament and be pulled out
I would not use any metal inside the nozzle personally
1
36 minutes ago, stu_le_brew said:just wondered which extruder feeder your UM2 has - is it white or black, black being the older and weaker in terms of torque
I have the black extruder block, but it seems to all be fixed finally!
hope it stays fixed
good luck
1
stu_le_brew 42
good luck
Edited by stu_le_brewLink to post
