GregValiant 786
The commands that control the mixing might be in your StartUp Gcode. I think they would be M163 to M166.
Your "real" extruders are T0, T1, and T2. If your StartUp Gcode ends with T3 or higher then it's calling for your "virtual" mixing extruder at the start of a print. Cura looks at the startup gcode as "That's what they want then that's what they're getting.". If your startup gcode ends with a "T" command try "T{initial_extruder_nr}". Cura will note that and replace the keyword with the extruder that starts the print. (the Curly brackets are required.)
In regards to the "empty" sign...have you picked nozzles for each extruder?
Edited by GregValiant
Princy557 0
Additional info:
When I print the mix is always 33%,33%,34%.
Even though I have set up my three PLA Green, white ,and black.
I have one heater, three extruders.
Is there a profile GEEETECH A20T for the Cura 5?
A better question might be. Why is my GEEETECH A20T not printing the set up colours I select. When I select the white, the item changes to white, when I select black the item changes to black ditto with the green. but dont print other than mixed
Regards
missed a word & Question
